Stator/Reg Question
Old Aug 12, 2005 | 09:10 PM
sgwkiip's Avatar
Default Stator/Reg Question
i just installed new 1's about 3 months ago, i went to start my bike and it died right away them i put a brand new battery in cuz the onld one tested bad and it started but didnt charged, i realzied the wire harness was melted and i made a new 1, and now that i made a new 1 i hooked everything up, the reg. started to smoke a little bit and then i went to test the voltage and it read 12, when i reved up it it went to about 12.7, i found what was shorted out and all, and im pretty sure i need a new reg again, but do you think i fryed the stator as well?, the reg was really hot as soon as i shut the bike off, please let me know what you think
Old Aug 12, 2005 | 10:06 PM
sirlimpzalot's Avatar
Default RE: Stator/Reg Question
From personal experience[:@]...
I find that the stators available on the aftermarket ( ie Rick's, Electrex, ect...) do not use the proper guage of wire on the stators, I have seen two fail very shortly after they were installed due to the fact that they cannot handle the heat generated by the electrical current and melt..causing the problem you have stated...
on my CBR900RR after the stator and electrical components were replaced with the FACTORY O.E.M. parts...no more problems. I know they cost more but at least they seem to last
I have seen this on a GSXR600 and my ld CBR900RR
Get the Honda stuff!!!!
Old Aug 12, 2005 | 10:16 PM
sgwkiip's Avatar
so you think its the stator or reg that i need to replace?, i mean like i said, it gives a little charge its at 12 when its started and then when its at 5500 rpm it goes to 12.7
Old Aug 12, 2005 | 10:24 PM
sgwkiip's Avatar
and also remember, the reg. started smoking as soon as i started the bike, let me know what you think
Old Aug 12, 2005 | 10:45 PM
Well the reg/rec either works or it doesnt...so if you can check the charging system and it is charging, then it is probally ok...but the fact that it was smoking would make me a little leary and probally replace it to ensure that I do not get stuck in the middle of nowhere
Old Aug 12, 2005 | 11:01 PM
sgwkiip's Avatar
should i just replace that to start off?, also what does the actually do? i thoguht the stator was the charging system
Old Aug 13, 2005 | 01:05 AM
the stator just produces the power..the regulator/rectifier "regulates" the power ( think of it as a fuse to protect your battery which can explode if it is overcharged!!)
Old Aug 13, 2005 | 01:13 AM
sgwkiip's Avatar
well the battery did go bad, i had it tested and i needed to buy a new 1, so should i just replace the regulator? and if i do is it a good chanve my problom will be fixed?
Old Aug 13, 2005 | 04:39 PM
sgwkiip's Avatar
fixed it was just the regulator again
peg grinder
Sep 12, 2010 07:20 AM
BStrand29
Apr 19, 2009 09:42 PM
iroc
Nov 26, 2008 10:14 PM
HAVOC
Feb 16, 2008 02:28 AM
jvmoak1
Feb 7, 2008 07:29 PM
