squeaky front brake?
Old Jul 21, 2007 | 10:18 PM
JonBrown's Avatar
Default squeaky front brake?
hey guys i have had my bike a week now and ridden about 1000 miles and the front brake keeps getting a louder and louder squeek when i stop but only at like 20 and below. is this normal or do i need to fix something? what should i look for? the bike has 13k miles on it do i need new pads? also it didnt do it until the last 200 miles or so
thanks
JonBrown
Old Jul 21, 2007 | 11:19 PM
NOSTUPIDZONE's Avatar
Default RE: squeaky front brake?
if the brake pads are ok i wouldnt worry about it
disc brakes are noisey sometimes
but look at the pads close to be sure
Old Jul 22, 2007 | 07:00 AM
onewheelneil's Avatar
if your pads r ok,you can go to your local autp parts store and get some "disc brake quiet". all you do is pull your pads off and smear some on,let it dry and put them back on,takes about 10 min.I just recently did that on my 93 and it fixed the problem.
Old Jul 24, 2007 | 01:14 PM
Bret's Avatar
I would suggest checking the front wheel bearings also. Get the front wheel off the ground and grab the outer edges of the tire and try to move it back and forth - do this with your grip at 3 and 9 o'clock as well as 12 and 6. Any wiggling or movement means your bearings are starting to go. Wheel bearings are often overlooked because they are out of sight, out of mind - but really should be replaced at 20-30k miles, or sooner if the bike has been subject to stunter abuse.
solidsnake808
Oct 10, 2012 07:01 PM
wagzhp
Riding Gear
Jul 15, 2012 05:57 PM
FLYOU
Jul 13, 2007 08:12 PM
jasonb
Sep 10, 2006 06:29 PM
ninetyfivehp
Jun 15, 2006 07:13 PM
