ANYONE SELLING A SET OF KEIHIN FCR 41MM CARBS??
Old Jul 22, 2007 | 08:22 PM
ducatijay's Avatar
Default ANYONE SELLING A SET OF KEIHIN FCR 41MM CARBS??
i'm interested in buying a set of keihin fcr 41mm carbs. new or used. can anyone help?? i jetted my stock carbs 3 times already. still looking for more power.....
Old Jul 23, 2007 | 05:48 PM
900rrjunkie's Avatar
Default RE: ANYONE SELLING A SET OF KEIHIN FCR 41MM CARBS??
# 1---do you have a stock 900???
# 2---are you racing the bike or riding street
# 3---900's run better with 39 not the 41's
# 4---i put the factory pro airbox mod with 162 mains and the bike is better then when i had the 39's on it keihin's suck on the street.. you cant warm the bike up the right way you can slam the throttle open when you wana and when you buddy walks over to you bike and thinks he is racer joe and twist the grip 3 or 4 times and screams ying ying ying all it does is **** you off and flood your bike and fouls the plugs?? i go with the factory pro kit ram air kit from air-tech and a plus 4 timming adv. ???
Old Jul 23, 2007 | 08:39 PM
ducatijay's Avatar
stock bottom-end. extensive valvetrain work. head was ported & polished, decked a few thou (i can't remember exactly, i just can never run high lift cams. it has yosh cams, have been degreed (few degrees from stock). larger intake valves. carbs already have factory pro stage 2 jet kit,hi-flow filter. also, it says on my receipt from machine shop, ported throttle bodies, larger butterflies, and oval out emulsion tubes. full d&d exhaust. ign advancer.
i think that's it.......
dynoed @ 132bhp on a dynojet, 128bhp on a mustang dyno. it makes very clean power. still not has fast as my '06 zx-10r, but a hell of a lot more fun.
the guys that built the motor, wanted to make the most hp with a stock bottom-end. trying to make the bike reliable. so far so good, except for a couple of shift forks(lol)...... i have a turbo charged 929 powered drag quad, also with a stock bottom-end and never any problems.
check outpics of both machines.......
[IMG]local://upfiles/4892/0069AEF837004F8E9C134BCFCC2B22B1.jpg[/IMG]
Old Jul 24, 2007 | 04:11 PM
sounds like you have everything you need just get a ramair kit and bigger jet i dont think you will ever get flatslides to be street ride-able.. i bought 39's from sudco and they never sinked right and they just werent fun on the street.. i sold them with filters and emulsions for $1300.00 if you do getthem buy new not used you never know what your buying and flatslides wearout quick on the street from the constant opneing and closing...
Old Jul 24, 2007 | 08:38 PM
onewheelneil's Avatar
I got a set of flat's I will let go for 500,but all I know about them is that they work fine I just took them off because I'm more in to wheelies than draggin.PM me if your intrested,I can find out some more info you want.I put the stock carbs back on the bike and noticed a huge power loss.I rode the bike for 2 weeks before I changed them...It was absolutley sic
ryano900rr
Nov 18, 2009 08:40 PM
ss6r
Sep 9, 2009 07:03 PM
ducatijay
Jan 9, 2008 06:42 PM
fredolococo
Oct 3, 2006 05:01 AM
