squeaky brakes
Old Sep 4, 2006 | 05:23 PM
jasonb's Avatar
Default squeaky brakes
What should I do if my brakes are squeaky.
The bike is brand new. And before i brang it in for the
first oil change check up and stuff it never made a noise like that
I think the wash with water did it.
They said they would wash the bike.
Basterds any idea what i should use.
Old Sep 4, 2006 | 07:38 PM
pacemaker's Avatar
Default RE: squeaky brakes
There are products you can get from auto shops for that, but as the bike is new, they may bed a bit and it will stop, it's sometimes caused by dust from the brake pads themselves. They may have used a high pressure spray when they cleaned it.
Old Sep 4, 2006 | 07:46 PM
kiggy74's Avatar
Are the squeaky or do they just make a grindy noise? Grindy noise is normal.
When in doubt, get contact cleaner/degreaser from and auto store and clean your rotors.
Old Sep 4, 2006 | 08:53 PM
jasonb's Avatar
no i hear a squeaky noise.
Usally when i am almost at a stand still.
Old Sep 4, 2006 | 09:08 PM
FastCRX's Avatar
i got it too. 06 f4i. i figured its just the brakes.
Old Sep 4, 2006 | 10:00 PM
doggy69's Avatar
Honda is losing the qc....
Old Sep 6, 2006 | 12:47 AM
spdrmns's Avatar
OK, listin up! the squaeky noise is caused from the brake pads vibrating inside the caliper. (completly normal) The way i have found that best takes care of it is to take out the pads and put some silicone gasket maker on the outside of the pad. ( up against the actual piston) that'le take care of it!
Old Sep 9, 2006 | 02:27 AM
fvaldez03's Avatar
good idea but there's also a spray call brake quiet. You can get at napa auto stores.I had the same problem and I used it it works. my brakes teacher told me about. good luck.
Old Sep 9, 2006 | 03:56 AM
NOchknstrips's Avatar
Most likely it is the pads vibrating in the calipers like mentioned above. This is another way
Get some Caliper grease and apply to any part of the pad that is making contact with the caliper. If you cant tell look for shiny spots on the metal surfaces. Apply a light coat to these areas as needed. Do not apply to the stopping suface. If you compress your calipers when taking them off( I doubt you will have to) but if you do make sure you give them a couple of sqeezes when they are back on the bike. Also look at your rotors. Make sure they do not have hot spots on them because that will cause sqeaking as well.
Old Sep 9, 2006 | 06:20 AM
DrDRFT's Avatar
How new is the bike? Sometimes it doesn't bed in properly. Might try and give it a few hard stops. Sometimes when you pussyfoot around with the brakes it glazes itself and you need to give your brakes a real work out everynow and then too get rid of the glazing effect???
