Regulator connector replacement
Old Feb 24, 2009 | 01:28 PM
robowensby's Avatar
Default Regulator connector replacement
I have a 93 900rr that has come to me with a burned up regulator and a missing connector, does anyone know the pinout to put the wires back in a connector or onto the regulator?
Old Feb 24, 2009 | 08:39 PM
camaropower's Avatar
I'm not sure exactly what you are looking for? Like a wiring diagram?
Old Feb 25, 2009 | 08:47 AM
robowensby's Avatar
The connector was missing, I needed to know which terminal on the regulator that each wire went to. I got a layout from Rick at Ricks motorsport electric. Looking into the connector on the regulator, with the 3 terminals on top and 2 on bottom. The 3 terminals are the yellow wires from the stator , the order is not important, the bottom left is the DC + (red wire) and the bottom right is DC - (Green wire).
Old Feb 25, 2009 | 05:07 PM
I'll go out to my bike and take a look
Old Feb 25, 2009 | 05:19 PM
(yellow) (yellow) (yellow)
(red/white stripe) (blank) (green)
The red/white is closest to the ground in the back row (closest to the bike when mounted) the green is closest to the seat in the back row
So if it is mounted on you are staring straight at it, the red/white is on the bottom, green is on top in the row closest to the bike, and the middle has nothing
Old Feb 26, 2009 | 07:54 AM
robowensby's Avatar
that got it man, thank you
Old Feb 26, 2009 | 04:33 PM
Cool no problem, glad to help
GK45241
Jun 30, 2018 08:08 PM
KRUSHER F3
May 8, 2010 01:34 PM
Billistic
Apr 22, 2009 08:48 AM
KRUSHER F3
Nov 30, 2008 11:17 AM
gaillarry
Aug 13, 2008 08:31 PM
