regulator/ charging system
Old Mar 23, 2006 | 02:22 AM
sd900's Avatar
Default regulator/ charging system
this is the second time i killed the battery. last time one of the wires from the stator to rec/reg was corroded. i needed the bike really bad so i did a quick fix. this time it was the other two yellow wires that just broke apart like a dry leaf. i replaced the wires and am now gettin 18+ volts at about 4k rpm. is this definately a regulator problem
Old May 5, 2006 | 02:20 AM
sd900's Avatar
Default RE: regulator/ charging system
well after rebuilding half the god damn wire harness and replacing the reg/rec i finally gave up and said "**** ELECTRICAL BULL****" and took it to the shop. turns out it was the ground THIS IS CRAP
skip954
Jul 28, 2009 02:54 PM
ba6669
Oct 17, 2007 09:42 AM
crodz600f4
Dec 15, 2006 06:03 AM
Team Stevil
May 10, 2006 02:36 PM
only_zeek
Sep 8, 2005 09:36 AM
