Less Power
Old Jan 8, 2007 | 06:21 AM
mervyn's Avatar
Default Less Power
Hey people, can anyone help me figure out the following?
My CBR900 has done around 51000kms and was just serviced with plug change and oil change done (according to service manual). I have now noticed that the power does not have the power it used to have. before i didnt have to give full throttle for it to speed up but now on a flat stretch and on third gear i have to give full throttle then it only slowly climbs 140-150kmph. there is definite lack of power and pickup
. could it be the plugs? could they be fake? How do you tell? its NGK and plug number is according to manual.
More so, what is the reason for the lack of power????
Look forward to your responses.... at the same pls tell of best plugs to use (both in standard and iridum plugs)
Old Jan 8, 2007 | 09:03 PM
DevenJames2005's Avatar
Default RE: Less Power
You need to make sure your plugs are gapped correctly. If they arent you wont get the right spark. Check in a service manual to get the proper gap range
Old Jan 10, 2007 | 01:33 AM
KingMushroom's Avatar
Yes, double check your gap and make sure you're not using too much oil. Make sure your plugs are seated all the way as well.
Old Jan 11, 2007 | 08:57 AM
mervyn's Avatar
ok i will check the gapping and whether it sits all the way down. what implications would having too much oil have???
Old Jan 11, 2007 | 04:29 PM
cloudbreakmd's Avatar
To much oil can cause the bikes engine to run without optimal lubrication. Funny sounding yes, but true. Also it can cause your speak plugs to foul (be coated with oil) as well. Good luck.
Old Jan 11, 2007 | 10:16 PM
It'll bog down/mud up the motor making it sluggish, just like a car. You also run the risk of blowing seals (and not the fish eating kind).
coolbluedab
Feb 7, 2014 07:13 PM
romanboy
Jan 19, 2013 12:53 AM
__Z__
Jul 14, 2010 10:00 AM
Karmakazi
Sep 29, 2009 09:58 AM
Certified Ryder
Nov 12, 2007 10:13 PM
