how is a 94 cbr 900 flasher wired up
ok so i bought this bike and the guy cut the wires to the flasher??i know the wire on the right goes to the fuse box, the one on the is hooked to the cluster, where does the middle one go?? The only way to get them to flash is to touch the middle one to the ground on the signals one at a time!!
Well Hopfully the guy that cut the wires left a little sticking out of the Turn Signal Relay.
White/Green Tracer goes to the Fuse
Gray goes to the Turn Signal Switch
Green goes to the Ground
Hope this helps It's right out of the 93- 95 Shop Manual.
