got my trailtech speedo wired & mounted!
Old Jun 14, 2012 | 02:05 PM
removebeforeflight's Avatar
Smile got my trailtech speedo wired & mounted!
So far im diggin it. I chose to go with the vector because 30$ more for a tach wasnt worth it on my budget. Made a make shift mounting bracket mounted through a hole that was drilled out for my old risers. Let me know what you think.
Old Jun 15, 2012 | 06:13 AM
Ultimeas's Avatar
Pretty neat. I would need a tach though. Allot of people say only rookies need tachs, but its an old habit from being into cars, I ALWAYS am looking at the tach.
Old Jun 15, 2012 | 01:54 PM
The trailtech vapor is awsome and it has a neat tach. Very good sleek option for a speedometer for a fighter.
Old Jun 16, 2012 | 11:48 AM
Also. I would reccomend this to anyone thats has considered this as an option. Very easy to wire up and free 2 day air shipping!
Old Jun 17, 2012 | 01:06 PM
95frankenF3's Avatar
i believe i figured out what dash i'm using now...
does it have the turn signal, hi beam, and temp lights?
and how did you run the wire harness to clean up the look of the front?
Old Jun 17, 2012 | 08:44 PM
It has a seperate "dash" attatchment that has indicators for that stuff.
And for my set up it was pretty basic wiring. Just a power cable. Speed and temp sensors which are seperate pieces that come with the package. Check out the trail tech website.
Old Jun 17, 2012 | 09:05 PM
Michaud85's Avatar
I would hit my rev limiter all day without a tach. Pretty neat looking tho. what color does it light up to at night?
Old Jun 17, 2012 | 09:52 PM
i will check it out... because ... well all my wires are resting on the fender since it doesn't move like so
i was looking for one with a tach as well because i learned on a cruiser and have a habit of short shifting or hitting the limiter
Old Jun 18, 2012 | 08:17 AM
@michaud it lights up white-ish blue
@franken this is the set up you can score with a tach for under 200$
Old Jun 18, 2012 | 11:10 AM
i was looking into these as well...
Koso DB-01R- Koso DB-01R Multi-Function Electronic Speedometer - BikeBandit.com
Danmoto Nano- Danmoto Nano [SP-00006] - $110.00
dimebagdave
Apr 23, 2013 11:18 PM
jbalber
Apr 23, 2013 11:52 AM
HuskerRed
Apr 30, 2012 09:06 PM
fordfenatic09
Aug 23, 2011 12:21 PM
Phil R
Nov 15, 2010 09:57 AM
