Help!! electrical tail problem
Guest
Posts: n/a
Hi!
I gort a 900rr aftr'97
I got an electrical problem to my tail.
1) both rear signal light do not work, the front signal light works!!
2) the brake light does not work, in both case front brake and brake pedal
3) the position light works!
First I checked the bulb, but the are ok!
I checked the connection under the seat, the 6's plug with 5 wires(orange, light blu, green, brown and green/yellow). the tester sayd there is power, but not on the brake pedal .. maybe is that switch.
but the rest???
I checked the 10amp fuse is ok!
all in common is the turn signal relay, but the front bulbs works intermittently...
can someone help me, please!!!
Thanks Salvo
Sorry for my english, I'm italian
but the rest???
Thanks Salvo
