HELP electrical problem
Old Jun 29, 2007 | 04:54 PM
empire x's Avatar
Default HELP electrical problem
Hello everyone. I went out for a ride today on my 1993 and all of the sudden it just shut off. I have no power and the battery is brand new. I checked the fuse box and all the fuses are good. Is there a main fuse or relay that i need to check. Thanks!
Alex
Old Jun 29, 2007 | 07:37 PM
Trips's Avatar
Default RE: HELP electrical problem
You may have the same problem as me.
https://cbrforum.com/m_330878/tm.htm
This is the soleniod, but is also the main fuse. It is on the RHS under the removable fairng. The fuse may be blown or the connector itself blackened from the current and old age.
Old Jun 30, 2007 | 06:36 PM
empire x's Avatar
what fairing is that located under....?
Old Jun 30, 2007 | 11:01 PM
pacojoseph's Avatar
Clymers says it's under the right side panel.
Old Jul 1, 2007 | 09:37 PM
bensben's Avatar
I had a similar problemwhen Ireplaced stock bulbs with higher wattage halogens.It melted the wires at the solenoid.Location: remove the seat, and find itnext to the right side of the battery box.Under nearest panel secured by oneplastic tab and one screw.
Old Jul 2, 2007 | 01:36 AM
Trips's Avatar
ORIGINAL: bensben
The 1st thing the guy asked me was did I have bigger globes in there. (not that I do) The fuse may not blow with the bigger bulbs, but the bike just cant handle it aparently.
Old Jul 3, 2007 | 09:34 PM
empire x's Avatar
well, the main fuse was blown so i need to go get another and see whats up
Thanks
01daell
Sep 2, 2021 07:46 AM
kwood
Jun 1, 2020 09:53 AM
vfrman
Nov 16, 2008 10:06 AM
hridlehuber
Apr 5, 2006 04:11 AM
dunn929
Dec 6, 2005 12:50 PM
