HELP electrical problem
Hello everyone. I went out for a ride today on my 1993 and all of the sudden it just shut off. I have no power and the battery is brand new. I checked the fuse box and all the fuses are good. Is there a main fuse or relay that i need to check. Thanks!
Alex
Alex
You may have the same problem as me.
https://cbrforum.com/m_330878/tm.htm
This is the soleniod, but is also the main fuse. It is on the RHS under the removable fairng. The fuse may be blown or the connector itself blackened from the current and old age.
I had a similar problemwhen Ireplaced stock bulbs with higher wattage halogens.It melted the wires at the solenoid.Location: remove the seat, and find itnext to the right side of the battery box.Under nearest panel secured by oneplastic tab and one screw.
ORIGINAL: bensben
