frame swap
did a little digging and on stuntlife, those guyes say the frames are direct swaps for the motors for all of the 900rrs. apparently it's a popular mod to throw the newer bigger engines in the older frames.
now that was for motors, so i'm not sure the fairings and anything else would swap over - but there were a ton of guys on there agreeing that the engine swaps no problem, and some of them said the frames did not change at all for the 900rr. i don't know how much of that's true
the main difference is the subframe, cant use a 93-97 subframe on a 98-99 and the other way either. other than that all is interchangeable. triple clamps on 98-99 are 1 inch wider as well. i have had all the different models
Dave
the frames are the same except for the sub frame 93-97 sub frame and 98-99 subframe are different. have different lengths on the attaching arms. the rear fairing mounts are different. you will have to drill and tap new holes, easy to do. i did it for my 95 frame with 98 front fairings. everything else is a direct swap
