frame swap
Old 06-18-2013 | 01:08 PM
rrandp88's Avatar
New Member
Question frame swap
will everything from a 95 swap over to a 99 frame. mine is damaged from someone trying to polish it and not knowing what they were doing.
Old 06-20-2013 | 09:10 PM
Conrice's Avatar
did a little digging and on stuntlife, those guyes say the frames are direct swaps for the motors for all of the 900rrs. apparently it's a popular mod to throw the newer bigger engines in the older frames.
now that was for motors, so i'm not sure the fairings and anything else would swap over - but there were a ton of guys on there agreeing that the engine swaps no problem, and some of them said the frames did not change at all for the 900rr. i don't know how much of that's true
Old 06-23-2013 | 10:21 PM
DisciplesAir's Avatar
its a pretty easy swap upper fairing support bracket and bolts hole on neck where gas tank bolts up are different. my 95 has a 99 tank on it, had to make a custom bracket out of a piece of metal
Old 06-25-2013 | 09:53 PM
garylkendall's Avatar
Default frame
the main difference is the subframe, cant use a 93-97 subframe on a 98-99 and the other way either. other than that all is interchangeable. triple clamps on 98-99 are 1 inch wider as well. i have had all the different models
Old 06-26-2013 | 04:47 AM
dvhttn's Avatar
Is the frame damaged physically beyond repair (bent or something) or is it just cosmetic? If the latter why not just get the frame powder coated? I was going to do this to mine at some stage. I fancy satin/matt black.
Dave
Old 06-26-2013 | 05:24 PM
Default frame
the frames are the same except for the sub frame 93-97 sub frame and 98-99 subframe are different. have different lengths on the attaching arms. the rear fairing mounts are different. you will have to drill and tap new holes, easy to do. i did it for my 95 frame with 98 front fairings. everything else is a direct swap
RonP93f-2
10-20-2010 01:29 PM
wiltse
03-30-2010 10:22 AM
N2TROUBLE
11-04-2008 01:22 PM
900rr_Guy
09-07-2006 12:34 AM
el_super_dan
04-06-2005 03:23 PM
