Blown 900rr Motor - Any Options?
Old Apr 26, 2009 | 09:02 AM
pluckerskid's Avatar
Post Blown 900rr Motor - Any Options?
Ok, I just blew my 93 900rr motor yesterday, to be more specific I spun a berring and possibly scorned the walls due to lack of oil (1 quart down).
Now my question is, what options do I have?
1. Do I rebuild?
2. Do I need to find another motor for sale?
3. Is there another swap I can do without major modifacation? (929, 954, 1000?)
Thanks for all your help!
Old Apr 27, 2009 | 06:56 PM
900FighterRR's Avatar
It depends on your time frame because a rebuild will take a few weeks and be the most expensive option. I wouldn't attempt any kind of swap without considerable fabrication skill and the tools to turn down spacers and perform welding. Used motors are always a gamble, but they can be had on Ebay for reasonable prices. Just gotta look at what you can afford and see whats out there. A rebuild by the way will cover all the damage that you did to the motor unless you ran it a while with the bearing spun, then youe bearing caps and support might be too damaged. If you piece out that motor I bet you could cover half the cost of a used one....thats your best bet.
Old Apr 30, 2009 | 08:16 AM
gmoooney's Avatar
929 Engine will NOT fit in the 900rr frame without considerable fabrication. You can bolt ANY 900rr engine in the frame with little to no changes.
Ive seen a few on ebay in the 3-500 range, just keep an eye open.
Old May 1, 2009 | 10:19 AM
Thanks guys! I am taking it in this weekend if the mechanic has time.
Old Jul 19, 2009 | 09:59 PM
lil8309900's Avatar
i have every part you need to rebuild that bike. call 2054477094
Old Jul 26, 2009 | 07:53 PM
toddmonster's Avatar
I can sell you a 99 engine not sure it will work with your wire harness though
Old Jul 30, 2009 | 08:43 PM
joe king's Avatar
1. Do I rebuild?
try to find an enginr so u can ride right away and in the mean time rebuild the other one.
Old Jul 31, 2009 | 11:02 AM
lil8309900's Avatar
Default lil8309900
I would just get one to rid eif i was you., and if you are going to build build it big. I mean like 945 or 970 or 997 or 1033
Old Mar 18, 2011 | 02:53 AM
bryanp97_SC33's Avatar
Exclamation Wtf blown motor
saw ur post u still got the engine mine is toast. Its 95 chasis 97 motor with all harness. Pretty sure direct fit. Let me know on the motor or anybody else with a 96-99 sc33
text call me 469-734-0270. Im from Dallas Texas. Area
JankCibberf2
F2 Tech
Dec 13, 2011 05:56 PM
pluckerskid
May 1, 2009 10:20 AM
Nhride
Apr 7, 2006 08:04 AM
