help i may have blown my motor
Old Nov 6, 2011 | 06:02 PM
JankCibberf2's Avatar
Default help i may have blown my motor
So I was filming for a friend of mine do standup wheelies on his busa and I'm up on first miss second and redline the **** outa first, the cct has been bad and making that horrible rattle sound but now that's gone away and it sounds like metal hitting the top end of the motor. Luckily winters coming through andd I'm trying to pick up a second job for fun moneyh so could someone direct me into what's going on.?? O an here's a video
Old Nov 6, 2011 | 06:06 PM
And link to video, sorry doing this all wit my phone
Old Nov 6, 2011 | 06:23 PM
And if that video fails here's it on YouTube, man I'm stressing sorry guys
Old Nov 7, 2011 | 12:21 AM
cbrmaxxam's Avatar
dont run it anymore until u take the valve cover off. im new to the cbrs but im sure they have a follower on the cam shaft. sounds to me like you broke one. its definatly in your valve train. just take ur valve cover off and take a pic and post it. look for anything that is differnt. dont worry man the motor is fine im sure.. just dont run it because u might have also broke a retainer or something. if ur motor swollows a valve it will be toast
Old Nov 7, 2011 | 11:20 AM
Anything?
Old Nov 7, 2011 | 11:25 AM
cobra1000rr's Avatar
Your video's are not showing up and well if your motor is junk there's always another motor for sale, I seen a few in CG ( craigslist ) for around $200-300. But if your motor is still running it can prolly be saved. Just depends what happened.
Old Nov 7, 2011 | 11:32 AM
Edited and fixed good sir
Old Nov 7, 2011 | 11:38 AM
sounds like a little rattle going on, did you replace the cct? It still sounds like its running on all 4, could be lifters need adjusted or the timing chain has too much play and its slapping around.
Old Nov 7, 2011 | 12:19 PM
i have not replaced the cct yet, that was the problem before and i still haven't fixed it. I just ordered the cct and the gasket and should be here in a couple of days. I was also thinking the lifters but i'll try that after the cct.
Thanks for the reply
Old Nov 7, 2011 | 07:17 PM
JesseAwesome's Avatar
That'll teach you to ignore your cam chain now won't it!
