98 frame swap
Old Feb 7, 2008 | 02:04 AM
splinter's Avatar
Default 98 frame swap
hey guys i got a bike that the frame is junk on its a 98 cbr 900 and i was wandering what year frames were interchangable with the 98 year. i kno there is only one other year but i forgot if it was a 97 or a 99 so if u guys could help me out that would b great iv been putting this project off all winter so far and tonight i fianally got thinking about it again and decided i need to just do it rather then having the bike and doing nothing with it.
Old Feb 7, 2008 | 08:09 AM
Manic's Avatar
Default RE: 98 frame swap
96-99's have the same frame.
I'm not 100% positive about this, more like 90%.
This question has been brought up before, do some searching.
Old Feb 7, 2008 | 09:41 AM
splinter's Avatar
yea i had found this info at one time but forgot. for sum reason i want to say that sum f them years u have to modify a braket and there is only one other yea that is a direct bolt in.
Old Feb 7, 2008 | 10:05 AM
Manic's Avatar
93-95 had a single bolt for the fairing stay, and there was a change to the frame on the upper rear portion (if you look at the side view of the frame the 96-99, near the rear is angled towards the front). Should be a direct swap.
GL, post up your finds.
Old Feb 12, 2008 | 10:24 AM
Jeff1980's Avatar
The '98-'99 frame is exactly the same. '96-'97 frames will work but had a more shallow rake angle. In '98 they reduced the steering head angle slightly (5mm if I remember correctly) but they lengthened the frame the exact same ammount so that the bike would have the same wheelbase. The '98-'99 frame is also stiffer
So, you can use '96-'99, everything will mount up correctly. But if you want it to ride exactly the way it was designed to, then buy a '98-'99 frame.
RonP93f-2
Oct 20, 2010 12:29 PM
wiltse
Mar 30, 2010 09:22 AM
N2TROUBLE
Nov 4, 2008 12:22 PM
900rr_Guy
Sep 6, 2006 11:34 PM
el_super_dan
Apr 6, 2005 02:23 PM
