97 CBR - Tire options or upgrade wheel
DigitalBulletz,
Did you end up going to the 17" wheel? I am also looking into doing that swap with my 97, and I will keep looking, but now I am concerned.
garylkendall said that the F2 would not work, but jasonchristopher is saying that both the F2 & F3 work.
Just curious what you went with if you did change, and what you went with.
Cheers,
Brad
Cheers,
Brad
the f3 is the easiest way using everything you already have and its a direct bolt in..
the f2 needs at least one modification that I know of and here are some other options as well.
94-97 vfr750 rim
vfr400
nc30
but by far the f3 is the most commonly one used and easiest to install
94-97 vfr750 rim
vfr400
nc30
Thank you for the information, I will keep my eye open for one.
Also, not to jack the thread, but just want to double check.
When putting on a "new" rim, the rotors stay with the rim correct?
If I pull off a F3 rim, I will also want the rotors that came with it, not keep the ones that are on the bike now.
Thanks
Brad
Thanks
Brad
BorderLineAlaska
Jan 5, 2013 11:36 PM
