1999 honda cbr 900rr
Old May 15, 2021 | 11:18 AM
honda rider 90s child's Avatar
Exclamation 1999 honda cbr 900rr running issues
so I got this bike on trade and it sat for 2 years. I emptied the tank and threw in some fresh gas and threw some seafoam in it, took the bowls apart and cleaned the jets and floats. did an oil change with mobil1 motorcycle racing oil 10w40, new k&n oil filter, had the bike running up to 215 degrees yesterday. took it for a short spin and it wouldn't go past 6k rpms and got it home. turned it off and restarted after letting it cool down, started back up with no problems just ran rough till it warmed up past 160. went to go start it today now it wont start. key is on, kill switch switched to on, fuel is on. it does have a leaky petcock(have a replacement on the way). I'll hit the start button and half the time it does nothing then flip the key off then back on and till crank but wont fire except one puff here and there. i already replaced the starter solenoid relay which seemed to fix this problem but find it hard to believe the solenoid relay went bad. any ideas? id like to get this bike up and running for this season.
just got the carbs back in at this point
yesterday when I had it running
Today on the trickle charger while trying to figure out why it wont start
Last edited by honda rider 90s child; May 15, 2021 at 02:06 PM. Reason: title not decriptive
Old May 15, 2021 | 01:13 PM
UPDATE! got it started but continuously back fired, the spark plugs in the bike are about a week or 2 old. The idle was all over the place, ranging from 1500 to 3000. slight ticking while running
Old May 15, 2021 | 02:58 PM
Update, after it doing what I said in prior update it is running like I state in main post. I'm just about as lost as can be right now
Old May 15, 2021 | 05:27 PM
Sounds like you are going to need to fully disassemble the carbs and thoroughly clean them.
Old May 15, 2021 | 08:41 PM
I agree with @hamlin6 . Sitting for 2 years and thinking that gas didn't varnish the carbs is a mistake. Just bite the bullet and do it. Give it the full Monty, dropping the bowls is not enough.
Old May 16, 2021 | 06:09 AM
For sure, ill be getting started on that today. Thanks
Old May 16, 2021 | 09:53 AM
@honda rider 90s child If you haven't purchased your gaskets for your carburetors, I have a recommendation for you. I've purchased from this company since 2016 and no issues. Better parts and significantly less cost. Their O rings are made from Viton and will last longer than OEM.
https://litetek.co/Carb_Kit_Honda_CBR900RR.html
The CBR900RR uses the same gaskets as the CBR600F3. This can be verified by looking at the "Related Fitment" section on the lower right.
https://www.partzilla.com/product/ho...bcf4283d818d23
Old May 22, 2021 | 01:30 PM
So great news it running like it's almost new off the floor except now it idles at 4k to 5k rpm. Going to undo the throttle cables and see if they are binding. I've adjusted the idle screw with no luck of it fixing it. Any ideas you might have let me know
skiingchik
Jun 5, 2017 01:11 AM
jdthompson0706
Jul 29, 2011 08:40 PM
jmcshane
Aug 17, 2010 08:11 AM
lyricalhalo
Jun 7, 2009 05:35 PM
Evo325
Nov 3, 2007 12:46 PM
