Won't start
My bike wouldn't start this morning. The engine won't turn, and everything is on correctly. Could this be that my battery is low on juice? My lights and all other indicators turn on, but I'm guessing I could still have a low battery. Also, I washed my bike the night before. Could I have messed something up from the wash? What should I check for?
ORIGINAL: alekinci
weird stuff...
did you get the wiring wet?
also, it can very well be the batt.
give us more details and hopefully we can get something done.
weird stuff...
Okay, I just got home and tried to start it and the engine isn't even priming, and this time the headlight is going out. Does that mean that this is the battery? I'm hoping thats all it is. I will put it on the charger and hopefully get it started. Any other ideas or confirmation of low battery would be much appreciated.
my bike with a charger reading of 85% on the battery would still prime and start. if the fuel pump isnt priming it means something in the starting circuit is off. kill switch, BAS, kickstand, clutch switch, something
but it should still turn over. if it doesnt turn over, and your battery is good. then check the starter relay. you can jump across the allen head screws with the key on and the starter should turn over.
Thanks. It did turn out being my battery. My gf got home from work, I got a quick jump from her, and it fired right up. I just took out the battery and put it on the charger.
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
JayBoCC2
Jun 23, 2009 10:23 PM
