suspension adjustment question ~200 lbs
Old May 13, 2008 | 06:59 PM
jutsin's Avatar
Default suspension adjustment question ~200 lbs
I know it's going to be different from person to person.. but I'm just hoping someone can offer some input as far as a place to start to how I should set up my suspension. I was pretty happy with where I had it at the beginning of last season, and since then i've gained a bit of weight and I'm just over 200 lbs. Anyone around my weight want to offer their settings that they're happy with so I have a place to start? Bike is an 04 600rr, pilot powers front and rear if that makes any difference.
Old May 13, 2008 | 11:10 PM
Jason748's Avatar
Default RE: suspension adjustment question ~200 lbs
Get it sprung correctly for you. Without the correct spring, you can't set the sag correctly. Without setting the sag correctly the suspension won't function in the optiminum area of stroke...
Start adjusting, But take notes of where your settings are now and keep fiddling with the adjusters, but TAKE NOTES so you can go back if you don't like something.
Old May 14, 2008 | 02:00 AM
SurfnSCal's Avatar
You might want to contact Race Tech they offer springs for your bike and you will be able to talk with them and with your weight, and riding style and terrain. They might be able to offer a few suggestions for spring rate on your fork and shock springs. Helps take some the guess work, but you still have to set your sag when you get then new springs! like Jason mentioned
scastillo13
Apr 8, 2009 08:19 AM
krobberts
Mar 28, 2008 01:18 AM
ptowntsi
Jul 15, 2007 01:31 PM
vkhamphi
Jul 4, 2007 11:00 PM
wxgsr77
Apr 5, 2007 03:59 AM
