Fork size question
Old May 11, 2008 | 04:09 PM
greybullit's Avatar
Default Fork size question
Are the forks on the 03-04's the same size as the 05-06's?
Old May 11, 2008 | 10:55 PM
Jason748's Avatar
Default RE: Fork size question
Nope, completely different.
Old May 12, 2008 | 01:34 PM
SurfnSCal's Avatar
No they are not. I believe that in 05 they switched from standard forks to inverted forks.
Old May 13, 2008 | 02:44 PM
greybullit's Avatar
that would explain why the clip on i got from an 03-04 didn't work on my 06, damn! thanks for the help
Old May 13, 2008 | 02:51 PM
jfunkRR's Avatar
Yes, they inverted the forks in 2005 but you can mount them on a 2003-2004 600 RR, which is my next big upgrade.
Check this link:
http://www.600rr.net/vb/showthread.php?t=101981
Old May 14, 2008 | 02:02 AM
SurfnSCal's Avatar
jfunk, what do you need to replace those forks? Just the upper and lower triple clamps? Do the steering bearings remain the same?
Old May 14, 2008 | 08:34 AM
jfunkRR's Avatar
Surfn...If you read the link above, this guy laid out everything for you...I would use whatever neck bearings comewith the new forks...I have found multiple sellers on 600RR.net that have full front ends for sale and will sell everything needed for around $500.
What parts will I need?The 05-06 front end swaps straight onto the 03-04 neck, so no special parts are needed.
These parts from your 03-04 can be reused:
*03-04 Wheel & Rotors
*03-04 Controls (throttle, starter module, high/low beam switch, etc)
*03-04 Neck bearings, bearing races, and dust covers (internals of neck)
*03-04 Axle
*03-04 Brake Master Cylinder
*03-04 Ram Air Covers (will need to be trimmed)
These parts from the 05-06 are needed for the conversion:
*05-06 Fork tubes
*05-06 Lower triple clamp (with neck)
*05-06 Upper triple clamp
*05-06 Clip-ons (will also need a new grip for left clip-on, more on that later)
*05-06 Wheel spacers
*05-06 Brakes (calipers, pads, lines)
*05-06 Front Fender
ffjacobs
Jun 30, 2008 03:55 PM
pyrplhaze
Jan 24, 2008 06:59 PM
nickandkristy02
Jul 21, 2007 10:37 AM
doman17
Nov 13, 2006 02:41 PM
wande00
Jul 25, 2006 07:16 AM
