stupid ?
Old Jun 30, 2007 | 04:58 PM
rdrink25's Avatar
Default stupid ?
what is the high side of the bike and the low side
Old Jun 30, 2007 | 05:03 PM
HAVOC's Avatar
Default RE: stupid ?
imagine low siding as if your going into a turn and the bike washes out from under you . high siding would be if you went over the "high" side (top of the bike) and crashed.
hope i explained that right. not very technical but you should get the idea
Old Jun 30, 2007 | 05:57 PM
BlindLOKI's Avatar
low siding is when the side of the bike closest to the ground goes out... ie left turn left side. High siding is the top part of the bike... ie left turn right side. its better to burn out, or even lowside, than to highside from what ive heard.
havoc is completely right just thought id try a bit more detail []
Old Jun 30, 2007 | 08:41 PM
CBRFREEK's Avatar
I seen Spies highside at Elkhart Lakes and still take second.... .4 seconds behind Mladin...but yeah lowside if you wanna go down or have to.... is the way to go...so you can slide...
Old Jun 30, 2007 | 09:18 PM
dragonium25's Avatar
Low side - you and the bike slide on the ground
High side - the bike throws you off, and you and the bikecatch air
Old Jun 30, 2007 | 10:36 PM
baxsom's Avatar
go into a curve really hot and lean too far
that would be a low side
now go into a curve really hot and stomp your rear brake
that would be a high side
TimBucTwo
The Hurricane Saloon
26
Nov 2, 2013 08:02 PM
MartiniRossy
Jun 11, 2009 02:42 PM
TD600
Jul 29, 2008 01:05 AM
dwschultzy
Dec 3, 2007 08:47 AM
adams_CBR600f2
May 22, 2007 03:18 AM
