stupid bar end...
however i loosen it just enough to where it doesnt do that and now its gone again... am i going to have a problem if i ride around for awhile without a bar end on there? has anyone else had this problem? how do i deal with this? trim down the grip some? thanks!
On a side note... I had considered getting new grips but all the sets i see in shops have closed ends. I'm assuming you need grips with open ends to work with a bike and bar ends but never seen any. Any ideas?
All you have to do is take a razor blade and cut the end out of the grip. The last set of grips I put on that is what I had to do. It works fine and you don't see the cuts because the bar end covers it up.
i took my progrips cut out a hole so my bar ends can go in. If you want to tighten it so the throttle doesnt stick just shave off some of the grip. And get some thread lock It will save you alot of headaches.. or just take both of them off and call it a day.
