Stator question & battery
Old Apr 8, 2012 | 03:43 PM
T£xaS Kid's Avatar
Default Stator question & battery
Ok so I recently bought a new shoni (I think that how you say it) battery and a new stator. After I installed both and changed the oil and filter everything was fine. when I was backing up all of a sudden it just dies, It won't power up or turn over but the battery was showing good volts. Today I looked at the battery and it read 0.03 so I am not sure why this happend
Old Apr 8, 2012 | 09:30 PM
NTXcbr600rr's Avatar
Go back through and recheck all your wiring. Maybe you crossed a wire and grounded something out which would drain the battery...
Old Apr 9, 2012 | 12:12 PM
T£xaS Kid's Avatar
What would be grounded if I used soder and heat shrink to reconnect the new stator to the old plug to reuse? I think it might be the recifer or something else but I am still searching.
Old Apr 9, 2012 | 03:28 PM
djbrower2's Avatar
honda is the best but that is there biggest down fall i had a 98 cbr f3 do the same thing. I replaced the stator the battery and the regulator then in a month they all died again. had to replace it all again and the wiring harness. Ran good then sold it a month later never heard back from the guy so I assume it worked fine. I hope this helps. Electircal is never fun.
Old Apr 9, 2012 | 05:02 PM
As in those wires may be shorted out somewhere and be draining the battery. Just sayin, doesn't hurt to go back through the wiring again
JimboCBR
Feb 6, 2013 08:58 PM
CaseAce000
Jun 18, 2011 07:57 PM
1998f3
Sep 28, 2009 11:19 AM
motoxxx43
Sep 4, 2007 02:49 PM
95ninehundredRR
Jan 6, 2007 09:11 AM
