Starter spins, engine won't.
Old Jun 10, 2007 | 04:06 AM
bikerboy's Avatar
Default Starter spins, engine won't.
Rode my'06 600RRall week to work, great weather, fun times. Parked in my driveway the other day, went out to dinner with wifey. Came home a couple hours later, started bike up, and pulled it into my shed for the night (only ran it for about a minute).
The next day, I pulled the bike out around noon to go to work, and when I went to start it, it kinda half-coughed, then quit, but the starter motor still spins. The starter motor goes, but the engine won't turn over now.
Any clue? The bike has around 6,000 miles, and has never given me any problems. I've searched all the other posts, and no one really seems to have a solution for this problem.
Old Jun 10, 2007 | 02:03 PM
meanstrk's Avatar
Default RE: Starter spins, engine won't.
Hope it's still under warranty. Sounds like the starter clutch may have come loose OR the starter bendix is screwed up. If it's not under warranty you can probably fix it yourself if you want to pull it apart.
Old Jun 10, 2007 | 07:23 PM
BlueDEV1L's Avatar
Check the kill switch?
Old Jun 10, 2007 | 09:52 PM
meanstrk's Avatar
Kill switch will not cause a starter to not engage.......
Old Jun 12, 2007 | 01:30 AM
bikerboy's Avatar
Actually, I went back and double checked--the engine is spinning, because I get "poofs" from the muffler while it's trying to start, so it's getting compression.
I've checked all the wiring harnesses I can see, pulled off the computer, disconnected and reconnected everything. Checked the air filter, peeked in at thethrottle bodies and stacks, checkedthe main 6-pin connecter for the coils, man I've been over every square inch of the bike.
I'm not sure, but I get the feeling that it's not getting spark, which might indicate that the ECM is bad, since none of the coilsare firing(or at least it would fire on some cylinders--you don't just lose all four spark plugs at once!).
Any thoughts?
Old Jun 12, 2007 | 05:30 AM
tomp's Avatar
You can lose at four spark plugs at once. Its called fouling your spark plugs. Pull them out and check them. You can clean them but you might as well change them while you have them out.
Old Jun 12, 2007 | 08:45 AM
meanstrk's Avatar
Check to make sure the fuel pump connector did not come apart. Happened to mine once....
optytrex
F2 Tech
18
Feb 7, 2015 12:18 PM
Ranger407
Jul 17, 2010 12:28 PM
nakedgardener
Aug 18, 2009 02:44 PM
fletchenv
May 12, 2009 01:41 PM
Billy Boots
Apr 4, 2007 04:50 PM
