HELP starter motor only spins won`t turn motor
[:@] The starter motor only spins wont turn the engine over it sometimes turns the engine one
rotation then seems to let go whats the problem and is it hard to get at the start cluch its aCBR 1000F 1988 can
anyone help us i have the book but still can`t figure out how its suposed to work
RE: HELP starter motor only spins won`t turn motor
If you hear a 'click' when you push the starter button, the start relais doesn't work;
either not enough power (dead battery for example), or a broken starter relais.
If the starter runs, but the engine doesn't, the solenoid doesn't kicks in far enough
to 'grab' the engine.
Try wiring the starter directly to your battery, this eliminates the starter relais.
If the starter runs, but the engine doesn't, the slonenoid needs replacement or adjustment.
If the starter spins, but does not turn over the motor.....starter clutch is bad....most people say the case has to be busted......Also do not jumpo the bike with a car...I did and now my bike does not charge.... My 1990 is in the shop as we speak $800 to 1000.00 to fix .......
ORIGINAL: iceman3ar
