starter not turning over engine
Old Aug 18, 2009 | 04:57 AM
nakedgardener's Avatar
Default starter not turning over engine
Hey to all my hurricane lovign friends..having been here for a while,just proving how reliable these machines are..but problem has struck,my starter wont turn over the engine,after installing a new starter the problem was not solved,battery is nearly new,recieving charge,starter clutch has been checked and not slipping,could the damper be slipping??
everything else seems in tact..help needed ASAP as my bike is in pieces at the mechanic shop.
Thanks to all..
Cheers,
Craig.
1995 model.
Old Aug 18, 2009 | 05:20 AM
Dean0's Avatar
Just for clarification - You have confirmed the starter is actually turning - ie you can hear it turning when you hit the start button ?
Old Aug 18, 2009 | 05:51 AM
Yep..looks like the damper..hopefully will be done without taking the engine apart..looks like we gonna make it..
Classic..you are the man with the plan..
Thanks dean as well..
will let you guys know whats up..
Cheers,
Old Aug 18, 2009 | 01:48 PM
Shadow's Avatar
Shalom, Craig !
Not sure if you've seen Stu's detail..................
http://www.stu.co.nz/cbr1000fix/
Old Aug 18, 2009 | 02:44 PM
STu shows the way....thanks guys for the help..
Shadow
Jan 21, 2011 04:22 PM
cs2jz
Dec 25, 2008 07:14 PM
bikerboy
Jun 12, 2007 08:45 AM
frankinbarnes
Mar 19, 2007 02:50 AM
