sprocket help pls!
Old Jul 7, 2007 | 05:34 PM
OneRedRider's Avatar
Default sprocket help pls!
thinking of upgrading my rear sprocket to a 1 tooth up and 1 tooth down on the front of my 05 cbr600rr...do i need to change the chain as well? are there any ups and downs or any add ons i might need to install? is this something hard to do?...any suggestions would really help..thanks!
Old Jul 7, 2007 | 05:43 PM
6zoomzoom6's Avatar
Default RE: sprocket help pls!
i believe ur posting in the wrong part of the forum my friend. try posting this in the current models 600rr part of this forum.
Old Oct 11, 2007 | 06:00 PM
knightslugger's Avatar
replace the chain if you don't want worn sprockets in 100 miles. if you don't, it'll be really chatty.
you'll need to determine your speed correction and install a Speedohealer brand speedometer calibrator. do not use the calculator on there, you need to determine your exact speed vs. your displayed speed. find a speed trap or a local police officer and ask him to laze you. determine your percentage difference and input that into the Speedohealer.
other than that, you're done. it's not really hard, unless you don't have the tools.
Old Oct 12, 2007 | 07:43 AM
Thinslice's Avatar
diffinelty replace the chain when replacing the sprockets, and vice versa. And one good thing to have is an impact wrench. And loosen all the nuts on the sprockets before removing anything. Use the rear brake to hold the tire/chain/and front sprocket in place and remove the front bolt with Impact wrench. TRUST ME!
Old Oct 12, 2007 | 05:10 PM
do not sue an impact gun for anything on a motorcycle. ever.
Old Oct 12, 2007 | 06:06 PM
baxsom's Avatar
ORIGINAL: knightslugger
very true
chain still on in gear rear tire on the ground
have a friend stand on the rear brake
loosen the front sprocket bolt with a breaker bar only
Old Oct 13, 2007 | 06:43 AM
Blue Fox's Avatar
Retired Moderator
I just turned over 11,000 miles and decided it was time to get the chain & sprockets replaced. The sprockets still look fine compared to new OEM ones, but it's usually a good idea to replace the sprockets and chain at the same time........therefore no premature wear on the chain and/or sprockets.
I just ordered a 520 conversion with stock gearing.....so I was told. Not sure what the hell that means, but it was cheaper than OEM sprockets and chain, and is a higher quality chain/sprocket set. Not sure if I'll feel a difference or not in performance.
Old Oct 13, 2007 | 06:57 AM
Blue Fox's Avatar
Retired Moderator
Not even on the windscreen bolts?
Myfirstcbr
Mar 22, 2013 09:40 AM
DunnRR
Jun 10, 2010 02:31 PM
