sprocket help pls!
thinking of upgrading my rear sprocket to a 1 tooth up and 1 tooth down on the front of my 05 cbr600rr...do i need to change the chain as well? are there any ups and downs or any add ons i might need to install? is this something hard to do?...any suggestions would really help..thanks!
replace the chain if you don't want worn sprockets in 100 miles. if you don't, it'll be really chatty.
you'll need to determine your speed correction and install a Speedohealer brand speedometer calibrator. do not use the calculator on there, you need to determine your exact speed vs. your displayed speed. find a speed trap or a local police officer and ask him to laze you. determine your percentage difference and input that into the Speedohealer.
other than that, you're done. it's not really hard, unless you don't have the tools.
diffinelty replace the chain when replacing the sprockets, and vice versa. And one good thing to have is an impact wrench. And loosen all the nuts on the sprockets before removing anything. Use the rear brake to hold the tire/chain/and front sprocket in place and remove the front bolt with Impact wrench. TRUST ME!
ORIGINAL: knightslugger
do not sue an impact gun for anything on a motorcycle. ever.
chain still on in gear rear tire on the ground
have a friend stand on the rear brake
loosen the front sprocket bolt with a breaker bar only
I just turned over 11,000 miles and decided it was time to get the chain & sprockets replaced. The sprockets still look fine compared to new OEM ones, but it's usually a good idea to replace the sprockets and chain at the same time........therefore no premature wear on the chain and/or sprockets.
I just ordered a 520 conversion with stock gearing.....so I was told. Not sure what the hell that means, but it was cheaper than OEM sprockets and chain, and is a higher quality chain/sprocket set. Not sure if I'll feel a difference or not in performance.
bowtieboy42
F2 Tech
Jul 10, 2012 03:53 PM
kreush33
May 21, 2006 12:28 AM
