Oil Change
Old Apr 30, 2007 | 08:47 PM
95_z28's Avatar
Default Oil Change
I am about to reach 600 miles on my 07 600RR. I was wondering what the best oil to use is. I also checked the manual and it says 10W30. So I guess thats what I should use. Any comments?
Old Apr 30, 2007 | 09:03 PM
cjp48's Avatar
Default RE: Oil Change
The short answer is use what Honda recommends, either the HondaGN4 (regular)or HP4(synthetic) and make sure you change the filter too.
In my opinion if you use any half-decent oil ( like one of the above)and change it regularly (2500-3000 miles), you'll be just fine.
The long answer is:there is a vast amount of information to read and learn, this topic is as indepth as you care to make it. Do a search on the Forum and you'll see.
Old May 1, 2007 | 08:07 PM
Fretless33's Avatar
ORIGINAL: cjp48
That's not the only oil the manual recommends either, it also recommends "equivalents"...pour elephant snot in as long as it's the right weight and viscosity!
Old May 1, 2007 | 09:14 PM
OGPlaya's Avatar
ORIGINAL: 95_z28
What I would do is call your local dealer the place whereyou bought your bike and ask them whatoil they use. Then stop by the dealer and buy the oil from them unless you can find the same brand oil else where it may be cheaper than the dealers. My dealer use "Pro Honda GN4 SAE 10-40 SJ on my bike.
stealthCBR929
May 24, 2012 03:15 PM
89HurricaneF1
May 7, 2012 09:52 PM
michealparks
Feb 10, 2010 12:16 PM
fiveoh
Jul 8, 2008 10:43 AM
otisdr
Aug 7, 2006 06:51 AM
