Gas shut off
Old Jun 27, 2007 | 12:45 AM
candyblueRR's Avatar
Default Gas shut off
I'm about to remove my gas tank to troubleshoot my alternator. I've only had the bike for about a week and this is my first one. I have have no idea where the gas shut off is. I was looking for something similar to an ATV gas shut off but have yet to find it, it's an 04. Thanks!
Old Jun 27, 2007 | 12:52 AM
bOwShEeZy's Avatar
Default RE: Gas shut off
as far as iknow they only have the fuel cut off valves on cruisers and dirtbikes and atv...but i had to re route my throttle cable and i was able to just unbolt the gas tank and just move it out the way..that should be enough space to work on the alternator..but i think you'll find it easier to just remove the right fairings and you should have plenty of space
Old Jun 27, 2007 | 01:01 AM
I guess I should word that differently, what do I need to do to make sure that gas doesn't go everywhere?
Old Jun 27, 2007 | 01:09 AM
formulafire99's Avatar
What alt. are you talking about? Do you mean the stator on the left side? If so , then there should be no reason to move the gas tank. You should just be able to take the fairing and stator cover off. The only thing you have to worry about spilling is oil that will come out when the stator cover is taken off.
Old Jun 27, 2007 | 07:02 AM
Hatebreed's Avatar
****, only a week and your doing somethign like that to it.... good luck, ima look on my manuel hold on....it said nothing pertaning to removing gas tank. jsut remove lower cowls, middle cowls and alternater cover. than it should be smooth sailing.
Old Jun 27, 2007 | 09:14 AM
OZ.CBR600RR's Avatar
If you need to take off the tank and fuel runs out just get some vice grips, bend/fold therubber fuel line and clamp them on. Don't clamp them to hard as if the fuel line is folded no fuel should run out. I haven't taken the tank out of my cbr but I have had other fuel injected bikes that didn't leak fuel as the fuel pump was in the tank and only works when there is power. ie, the key turned on. Unplug the fuel pump and it doesn't work. See how you go It really shouldn't be a problem if you used the vice grips.
Old Jun 27, 2007 | 10:33 AM
In another post pertaining to an alternator problem, someone with a haynes manual posted some troubleshooting steps, one of them was to remove the gas tank and disconnect a yellow 3 prong connector. That is why I am taking off my gas tank. Thanks for the replies.
Old Jun 27, 2007 | 02:27 PM
knightslugger's Avatar
ORIGINAL: candyblueRR
which is true, but you don't physically need to remove the tank. it rotates rearward to expose what you need.
F 16Mech
Jul 24, 2011 07:03 PM
launchba
Jun 12, 2010 08:32 AM
rnora
Jul 27, 2008 04:18 PM
rangerscott
May 16, 2008 06:59 PM
seebeeare21
Aug 21, 2007 07:31 PM
