bike just shut off
Old 07-25-2008, 11:18 AM
rnora's Avatar
Default bike just shut off
I hope some one can help me. Last night on my way back from Frisco'sI was cruising along and all of a sudden the bike just shut off as if it was out of gas.I stoped and checked my tank was almost full. Any pointers on what might be the problem?
Old 07-25-2008, 12:22 PM
Northernfirepower's Avatar
Default RE: bike just shut off
Is there power to everything? If not I'd check the battery terminals to be sure they are secure
Old 07-25-2008, 12:26 PM
rnora's Avatar
it cant be the battery, every thing works, bike turns over but it will not start? Lights, horn, etc all is fine.
Old 07-25-2008, 02:01 PM
I'd pull a plug and see if you still have spark. If not then itd be time to check some electrical spots...kickstandor neutral switch.
Old 07-25-2008, 09:33 PM
willduce's Avatar
happened to me once too..its like the fuel pump had an aneurysm or somthing..i choked it and it fired right up, ran fine ever since
Old 07-26-2008, 12:37 AM
rnora's Avatar
i have tried everything, i am thinking it may be the starter. does any one know how i can test it the starter?
Old 07-26-2008, 08:31 AM
On my wifes F3 she had a similar problem. Died wh1le riding and it was as if it ran out of fuel.
Ended up replacing the fuel pump. So far no problems but its only been a couple of weeks. A bad starter would not cause your bike to stop running if you are riding down the road.
Old 07-26-2008, 12:10 PM
rnora's Avatar
I mint to say fuel pump, not the starter.
Old 07-26-2008, 04:23 PM
When I was troubleshooting her fuel pump, it passed with flying colors. The relay was fine and the flow rate was more than the spec. I believe hers was heating up and getting stuck.
Old 07-26-2008, 06:37 PM
rnora's Avatar
So I by passed the fuel pump/filter and she fired right up!!! Is it safe to ride like this???
Quick Reply: bike just shut off
