07 hotbodies flush mount front turn signals
Old Jun 23, 2007 | 12:13 PM
ryman546's Avatar
Default 07 hotbodies flush mount front turn signals
Ok installing the hotbodies front flush mount turn signals and havent ever tackled anything electrical before. My question is where do i cut the wires at. Should i take out the actual light bulb and 3 screws and cut at where it attaches to the bulb housing or should i cut right where it goes into the plastic so incase i need to put the stockers back on for some reason? Thanks.
Sorry if this doesnt make much sense...
Old Jun 23, 2007 | 09:18 PM
D2VW14_20's Avatar
Default RE: 07 hotbodies flush mount front turn signals
Just cut were the stock connector is and wire it in.
Old Jun 24, 2007 | 11:33 PM
edubbs's Avatar
dude, read up on diodes/resistors before wiring anything son. LED's take milivolts and u'l fry your circuit
Old Jun 24, 2007 | 11:39 PM
baxsom's Avatar
its not that hard
if you dont mind losing your running lights then it is easy
cut oem plug off of oem signal
wire the oem plug to new signal
green is ground
solid is turn signal
the striped wire is the running light
if you want to keep your running lights go to www.hooliganbiketech.net and check into the mototek flushmount installation how to.
it shows how to wire in diodes so you can keep your running lights on standard bulbs. i did it when i installed my new signals and they work great.
if the signals now flash too fast for your taste go to radio shack and get two 20w by 8 ohm resistors and jump the green ground wire to the turn signal wire (solid color)
this will slow down the blink rate
easy stuff
Old Jun 25, 2007 | 11:41 AM
ryman546's Avatar
yah it was pretty easy...but the actual light never is actually flush with the body...the back sticks in a little. I'm assuming this is how its supposed to be as the washers on make the front come out more and the back come up flush.
Old Jun 27, 2007 | 07:30 PM
baxsom's Avatar
yep, the hotbodies sit into the body panel
if you want otherwise go with protons at about twice the price
Jay_J
F4i - Wanted
Aug 18, 2010 02:57 PM
ccexpress2002
Apr 19, 2009 08:50 PM
Cun0144
Sep 4, 2008 11:23 PM
929_boosted
Nov 3, 2007 11:31 AM
Ludefreak
May 17, 2007 03:45 PM
