flush mount front turn signals?
Old Nov 1, 2007 | 06:53 PM
929_boosted's Avatar
Default flush mount front turn signals?
i wan to get some flush mount...but like real flush..not the bulky ones that stick to the side...i want ones that go to the 929 and are real sleek looking...anyone have any preferences?
Old Nov 1, 2007 | 08:23 PM
kodiak1122's Avatar
Default RE: flush mount front turn signals?
PROTON
Old Nov 1, 2007 | 09:45 PM
they will be a direct fit in on my 929 correct...no adapter pieces i have to buy? wont leave a bulky whole unfilled in the panel? and will they be a direct plug and run? or do i need to splice into...?
Old Nov 2, 2007 | 11:11 AM
Triax's Avatar
They are a direct fit just need to plug the correct wires in.
Old Nov 2, 2007 | 04:16 PM
skubysnak's Avatar
I went Proton's as well. I'm happy...
Old Nov 2, 2007 | 05:37 PM
i take it everyone is satisfied?
Old Nov 2, 2007 | 09:10 PM
dd's Avatar
dd
got pics?
Old Nov 2, 2007 | 11:26 PM
NY Erion929's Avatar
If you want them to be totaly flush you can do a custom set (very easy)
my friend used the smoked hotbodies signals from a 06-07 1000rr (they are the exact same size hole as the 929)
We cut out 2 squares of plastic (roughly 3 inch squares) and epoxied them to the inside of the fairing covering the signal hole. then took a drill and drilled out 2 small holes (lign up signal for location) one for the wires the other for the little bolt that holds them in. mounted the siganls and wire them up..they sit perfectly flush with the cowl ill try and get pics if i can
Im going to be doing the same to mine this weekend by far the nicest "flush" mounts
Old Nov 3, 2007 | 11:31 AM
do put some pics...i like that idea
Jay_J
F4i - Wanted
Aug 18, 2010 02:57 PM
ccexpress2002
Apr 19, 2009 08:50 PM
rrspeedster88
Feb 5, 2009 09:40 AM
ryman546
Jun 27, 2007 07:30 PM
Ludefreak
May 17, 2007 03:45 PM
