Front end shaking?
Old Mar 12, 2008 | 01:15 PM
dpeach06's Avatar
Default Front end shaking?
Just now gettin my bike out for the new year and I've noticed the front end shaking a bit. Like when I hit a big bump and especially when the front wheels gets in cracks or grooves parellel to the road it seems to shake a bit. This is one part of my bike I"m not very familiar with. What do you think this could be? Bad wheels bearings? Something loose maybe? Thanks!!
Old Mar 12, 2008 | 01:39 PM
bobjoezx's Avatar
Default RE: Front end shaking?
hmm need a few more details.. but check air pressure.. or head bearings.. does your triple tree move when u come to sudden stop
Old Mar 12, 2008 | 04:16 PM
dpeach06's Avatar
ORIGINAL: bobjoezx
Pressure is fine and nothing seems to move at a sudden stop. I think it might be my tires from being in the cold all winter... I'll take her out for a ride now and see if I can figure out anything else.
Old Mar 12, 2008 | 04:28 PM
bobjoezx's Avatar
hm ya hard to diagnoise a problem like this over the internet. .try to find somone knowledgeable in your area to take it for a spin.. just might not be used to it becuase of the winter..
Old Mar 12, 2008 | 10:46 PM
cyber00677's Avatar
my old f4i's bars shaked when i has hitting groves and cracks parrale to my direction. scared the crap out of me sometime. it was horrible when i was on a road they had stripped to be repaved. i thought it was just normal, never figured it out.
Old Mar 12, 2008 | 11:04 PM
Illushun's Avatar
Did you get a good heat cycle back into the tires? Did you compress and rebound the forks a bunch of times before you took it out? Did it happen when you used brake? If you put the bike up on a front stand, try having someone hold the bars, and then you grap the front wheel at about 4:00 and 8:00 (reference points on the wheel) and give it a lite wiggle. If you feel anything other than tightness, this could be part of the problem. And to compliment what Bobjoezx, said, by moving your bike forward and feeling in the clipons, do you feel and movement in the upper triple clamp? If you feel anything start at the brake pads first, sometimes one or both of the calipers will hang up slightly on either side and can cause the shake.These are just a couple questions that I do, to kinda get things moving around again.
As far as hitting stripped pavement, that will cause a slight vibration/shake in the bars but not necessarily in the headstock bearing. Make sure that you check nuts and bolts with a torque wrench during diagnosis. Don't forget to let the board know what you found out.
Old Mar 13, 2008 | 05:53 AM
iroc's Avatar
or it could be slight flat spots from sitting in the same place all winter?..
my .01 (new 08 discounted price)
Old Mar 13, 2008 | 07:04 PM
Woody6799's Avatar
Cupping, (I dont think so but it is a possibility), check for your wheel weights, check/replace your front bearings, steering stabalizer, all these are viable choices/problems but your best bet would be a shop.
Old Mar 14, 2008 | 01:37 AM
dpeach06's Avatar
Well didn't get a chance to do much today... After a warm day yesterday it snowed AGAIN today. My garage isn't insulated or heated so when it's below 20 degrees I don't venture from the house much. Will be back in the garage as soon as it warms up a bit. I'll be sure and keep you all posted. Thanks for all the tips, I will give everything a shot when I get back to it.
justing66
Jul 1, 2014 06:34 PM
Rabid
Jul 5, 2008 11:17 AM
Cletus
Dec 5, 2007 07:29 PM
demat
May 5, 2007 11:44 AM
devildef2002
Oct 19, 2006 04:48 AM
