Help! Front Wheel/Steering Shaking
Old Jun 18, 2008 | 08:08 PM
Rabid's Avatar
Default Help! Front Wheel/Steering Shaking
Hi guys,
Finally registered and posted (lurked for a few months.. )
I have a question. I have a 1988 Honda CBR600F1 Hurricane (29k miles). My handle bars shake at approximately 65mph everytime I go on the thruway. This problem is ONLY at ~65mph - anything more or less does not make it shake. My wheel weights are still in place on the front wheel. What parts should I be checking to see what's causing the problem? Bearings? (I have a Clymer manual but not sure where to start - I want to see if I can do some of this stuff myself before consulting the dealer) My front tire looks like it could be replaced in the near future but how could I tell if this is causing the problem?
Thank you so much in advance!
Rabid [sm=hail.gif]
Old Jun 19, 2008 | 12:55 AM
Billistic's Avatar
Default RE: Help! Front Wheel/Steering Shaking
I had the same problem at approx. 100 mph on mine with an old tire. I got a new tire and the shaking went away.
If you need a new tire then that willl probably cure the shaking problem.
Old Jul 5, 2008 | 11:17 AM
newnut's Avatar
hi there, most likely probs would be a warped front break disc or as u said loose headset bearings, altho if ya tyre needs changing i'd do this first as u dont wanna test high speeds on a dodgy tyre, hope that helps.
BlueBerryPie
Nov 3, 2012 04:58 AM
SpiritBreaker
Mar 9, 2007 12:05 PM
devildef2002
Oct 19, 2006 04:48 AM
vego12
May 31, 2006 02:22 AM
