Problem with Steering after replacing front wheel/rim/tire
Old Mar 8, 2007 | 04:41 PM
SpiritBreaker's Avatar
Default Problem with Steering after replacing front wheel/rim/tire
I just replaced my front wheel/rim/tire. I noticed while my bike is parked. When moving the handle bar, the steering is very hard and heavy and stiff.
Also while riding, i noticed on turns the steering wheel wants to turn, unless i restrict it.
For example, doing a right turn, the steering wheel would turn right heavly, unless i restrict it by not allowing it to so i may clear the turn. This happens on both sides.
Prior to this, with my old wheel/rim/tire, everythign was the opposite.
While parked, it was easy to turn the handle bars, they were light.
On turns, i had to turn the steering wheel myself, it was easy and light. Any ideas?
Old Mar 8, 2007 | 04:45 PM
Candymanmo06F4I's Avatar
Default RE: Problem with Steering after replacing front wheel/rim/tire
Not sure but if replacing tires on cars sometimes has issues with the allingment maybe you either screwed or put the bike tire to tightly, too loosely or its not sitting in its fitting correctly.
Old Mar 8, 2007 | 05:01 PM
ampfp's Avatar
Putting a new tire sometimes has the effect of making it harder to turn while at rest - since the new tire is gripping the road properly. If your older tires were over inflated/worn out/hardened then that would make steering feel lighter...
I'd start with checking tire pressure, since low tire pressure can give the effect of harder turns.
I'm confused when you say you had to turn the steering right on right turns when on your older wheel... at any speed above say 15mph, one always has to counter-steer, i.e. stop the bars from turning... (if you took the MSF course they taught push right - lean right - turn right). It's actually intuitive, but on lighter bikes you hardly notice it. It's the heavier bikes that need a definite push on the bars. In fact, if you try to turn right and turn the steering right also, the bike will probably high-side after locking the steering right.
This is because if you try to lean right, the precession of the rotating wheel tends to turn it inward (right).
Is it hard to turn the steering when going at say 5-10mph?
Old Mar 8, 2007 | 05:26 PM
Tahoe SC's Avatar
let me guess...you're running pilot powers now?
Old Mar 8, 2007 | 06:14 PM
Jaybird180's Avatar
I was thinking geometry too. Like his tire profile is too tall and he didnt say that he replaced the rear.
Are you saying something bad against the Michelins again?
Old Mar 8, 2007 | 06:48 PM
SchiraF4I's Avatar
My girlfriend's bike has that same turning thing but hers is lowered once you get used to it its all good ....Is your bike lowered at all?
Old Mar 8, 2007 | 07:08 PM
Triax's Avatar
Did they tighten the yoke nut really tight?
Old Mar 8, 2007 | 07:10 PM
Tahoe SC's Avatar
ORIGINAL: Jaybird180
i love michellins...haven't used them on MY bike per se, but i think they are great tires!
Old Mar 8, 2007 | 10:07 PM
ORIGINAL: ampfp
The tire pressure is fine. and normal.
Yes, i am refering to going at slow speeds between 5 -20 mph. Turning right, the wheel leans towards the turn at slow speeds very heavily. Its like if i let go my hands, the handle bars with automatically turn right all the way. or left which every dirrection i'm turning. . This has never happend before, of course at higher speeds i understand the lean etc... I've been riding for 7 months, and this is the first problem i have encountered ever since i replaced my front wheel.
Old Mar 8, 2007 | 10:13 PM
ORIGINAL: Triax
I purchaseda used front wheel because my old one was dented. and it came already with dunlop tires, and rotors.
I just followed the owners manual on how to replace the front wheel.
Which nut is the "Yoke nut"? I'll try to rescrew it ?
