First maintenance
Old May 17, 2006 | 03:56 AM
dragonium25's Avatar
Default First maintenance
Hey guys, I'm about to do my first bit of maintenance work on my bike since I got it about a month ago. I'm a noob at this stuff with my bike, but I'm pretty handy and learn pretty quickly The guy I bought it from had been taking pretty good care of it and I wanna keep that up. He gave me some suggestions of oils/lubes to use, but I wanna get some more advice from other people as to what they use and how to use this stuff.
1. Engine oil - Synthetic Mobil 1 Red Cap, 15W-50. Is this the best I can use or is there something better or similar. Do I also need to get new oil filters/gaskets? anything?
2. Brake fluid - Motul DOT 5.1, now on my bike it says to only use DOT 4 brake fluid, so will this be okay. How do I know when to change/refill it?
3. Chain Lube - Motul Chain Lube, I know I need to clean the chain first, but what should I use to clean it. I've heard a lot of people use WD-40, but others have said not to.
4. All purpose lubricant (levers, cables) - Belray 6-in-1, how do I use it? where do I actually put it?
Is there anything else I should do to maintain my bike. Other parts I need to lube or oil or tweak to ensure it runs properly? I know these must be pretty trivial questions for some of you, but I really want to do it right and don't wanna mess anything up. I appreciate any help anyone can give me. Thanks [sm=hail.gif]
Old May 17, 2006 | 02:03 PM
Jet Jockey Z06 Vette's Avatar
Default RE: First maintenance
I will also watch this post as I have some of the same questions. Mine is coming up on the first 500-600 miles & I'm going to change oil, etc. I'm thinking of taking her to the stealership for a once over to check torque values & tighten things that might need tightening, etc. But in general I want to do my own maintenance.
lewisF4i
Jul 12, 2012 08:59 AM
MrSplean
Oct 26, 2008 04:04 PM
Glocker23
Apr 29, 2007 04:18 PM
whiteav6
Jan 7, 2007 06:24 PM
dragonium25
Aug 26, 2006 07:26 AM
