Electrical Problems
Old May 9, 2011 | 09:58 PM
dsmith3737's Avatar
Default Electrical Problems
Hello, I am new to this forum and new to owning a CBR...my first motorcycle infact. I purchased it about a month ago and tonight I started having some issues. I pulled up a little wheelie and came down sort of hard on the front end. Nothing crazy just popped it up a little bit but, when I came down my display, rpms, front center white led light, and the taillight all stopped working. When I pull either hand or foot brake it all lights up and shows me accurate speed but, the second I let go it dies. My brake light lights up ONLY when pulling the brakes but, not when riding. Turn siganls and headlights all work. Also when I am holding the brake in and the display is lite the check engine and the red box next to it are lit too. Has anyone had this problem or know what might be going on? Any help would be very much appreciated, Thanks!
Its an 2009 CBR 600rr with 5k on it btw.
Old May 9, 2011 | 11:11 PM
Shadow's Avatar
Loose connection in the wiring - probably an earth wire to have all that go funny at once, or a multiplug has come unplugged.
Old May 9, 2011 | 11:22 PM
9-5=4rr's Avatar
......... Well welcome to the forum ... nice of you to bring a nice lil headscratcher with you along the way ... lol
Checked your fuses lately ?? .....
Old May 10, 2011 | 02:20 AM
yumoncbr's Avatar
August 2011 ROTM
Is there normal lifespan for fuses? Should I be checking mine also?
Old May 10, 2011 | 02:27 AM
9-5=4rr's Avatar
Not that I know of honestly ... they're just consumable items that go on the bike (like tires, oil, chain/sprockets, headlights ... stuff like that) ... but their lifespans vary depending on the fluctuation of voltage on the bike ... too much voltage and they pop (as I'm sure we all know) ... theoretically they could last for a very long time if the voltage stayed constant on all your electronics ...
Old May 10, 2011 | 06:55 PM
dsmith3737's Avatar
Im hoping that it is only a loose connection but, I also noticed tonight when I got home that when I am taking off in first gear it feels like its almost bogging out, not sputtering but just not taking off as quick as it should. Almost as if the fuel injector isn't pumpin it in fast enough but, it only happens in 1st. Anyone know what that could be? I set up an appointment tomorrow at the powersports store across from my work. Ill let you guys know, thanks.
Old May 13, 2011 | 08:31 PM
dsmith3737's Avatar
Turned out to be a loose wire that caused a fuse to blow! Easy fix..for them, thanks for the help guys!
dcaldwell
Oct 6, 2009 10:20 PM
thetrick13
Aug 11, 2009 10:13 AM
f3gatorfan3388
Nov 19, 2007 02:28 PM
rblevins4130
Nov 10, 2007 04:36 PM
dizzie56
Jul 9, 2006 01:59 AM
