chain
Old May 15, 2007 | 05:12 AM
bigcha40's Avatar
Default chain
anyone else have the problem of the chain throwing grease all over the rim? it seems like everytime i clean the back rim and go riding even for just a few miles when i get back its covered in the chain grease. just wondering if this is normal or its just mine thats doing it.
Old May 15, 2007 | 06:07 AM
OZ.CBR600RR's Avatar
Default RE: chain
Yes it's normal. every bike I've ever had has thrown chain lube on the wheel and also up the underside of the tail. just clean it off with some brake cleaner.
Old May 15, 2007 | 06:40 AM
MADMN's Avatar
Default RE: chain
you should only clean an O ringchain with kero and you can get stuff that doesnt flick off
OZ how's the bike going ?
Old May 15, 2007 | 06:59 AM
Default RE: chain
I don't think he was asking about cleaning the chain, just the wheel. I disagree with the whole only use kero thing. Anything is ok as long as you don't soak the chain in it. I use a petrolium based degreaser but only leave it on for a few minutes and them wash it again with detergent and hot water.
As for my bike. It's all together except for the body work. I took it for a quick ride on the weekend and it's all good. Was only about 10-15 min as there wasnt any body work except for the tail and stop light. I was going to ride longer but everyone was looking at me and I was worried if a cop saw my I would be done big time.
Old May 15, 2007 | 08:08 AM
MADMN's Avatar
Default RE: chain
i read somwhere that kero is the only thing that doesnt eat away at rubber
i remember on one of my bikes i cleaned the chain then use oil and went out for a ride , **** i got some serious tail wiggles the rear tyre was coveredin it lol
Old May 15, 2007 | 09:37 AM
Default RE: chain
I was a sales rep selling DID wholesale for 5 years and never had anyone have a problem cleaning chains with degreaser as long as it's not left to soak. The O rings on modern chains are very resiliant as most aerosole cans of lube use some form of thinner to make them easy to apply. Thats why if you spray it out it's very runny and then after 10-30 seconds it goes all thick and sticky. However if you soak the O rings in strong petrochemicals for a long time. And it doesn't matter if it is kero, petrol or even thinners (only the time will change) the rubber will always soften and then when the O ring dries out it also hardens and that is where most of the damage comes from. So if you use the chemical only long enough to disolve the chain lube, which shouldn't take more than a minute or so if it is kept fairly clean.then wash it off you will cause minimal if any damage and the damage you may cause will be much less than the grit and crap that would be stuck in the lube and acting as an abrasive whould of caused..
Here endeth the lesson and thank you for reading my dribble.
Old May 15, 2007 | 02:13 PM
bigcha40's Avatar
Default RE: chain
thank for the info guys ill try it out and see how it goes
Old May 15, 2007 | 04:28 PM
alekinci's Avatar
Default RE: chain
I dont see this to be a problem. You should just follow what everyone said and clean the excess oil of the chain.
Old May 15, 2007 | 04:50 PM
bigcha40's Avatar
Default RE: chain
thanks for the info guys it still throws the grease on the rim but not near as much as it was thanks
chace
Old May 15, 2007 | 07:47 PM
cksean's Avatar
Default RE: chain
i clean my rims also with concetrated simple green after cleaning the chains...
davedude44
Jun 28, 2012 12:22 PM
TheHeggi
Aug 11, 2010 04:58 PM
Perranomous
Apr 19, 2009 03:04 AM
crookedeyemotocross
May 4, 2006 10:14 AM
