Bike won’t start form start button
Old Aug 2, 2021 | 01:59 PM
Rodd's Avatar
Default Bike won’t start form start button 06 Honda cbr 600RR
I can’t get my bike started from button, but it will start if I jump starter relay. I have went through all the test of checking fuses, current, pump priming, new starter, new battery, cluster lights up, but when I hit button headlight flicker will not start. I’ve tried pulling clutch in stand up in neutral nothing happens I looked for burnt and broken wires none that I see. Can anyone help with this issue Please.
Old Aug 10, 2021 | 07:17 AM
@Rodd If the 600RR is like most Honda's, the start switch has 2 sets of contacts in it. One is responsible for turning off the headlight (so more power can go to the starter) and the other set is responsible for engaging the starter relay. Have you used a multimeter to test/check the operation of the starter switch?
Old Aug 11, 2021 | 11:39 PM
Rodd's Avatar
[QUOTE=Rodd;1345200]@IDoDirt I have used a multimeter to test/ check everything found out after new starter had bad ground connection and some how that my wire running from starter switch on handle bar got under steering section area and got crushed cutting off power to starter relay where I wasn’t getting any power. Thank You for tip to start looking I purchase a new starter relay also just to be safe and it started right up first hit man I’m ready to ride after three weeks of down time Thanks Again Rodd
Old Aug 12, 2021 | 08:11 PM
@Rodd Rock and Roll man, that's great to hear. Enjoy the ride.
thePUNISHER
Apr 22, 2017 08:32 AM
IrishboyWRX
Jun 19, 2013 10:49 AM
twiceborn00
Aug 29, 2009 11:21 AM
crackajack
Jun 11, 2009 08:26 PM
cbr_newbie
Jan 7, 2007 06:10 PM
