What is the recommended air pressure?
Old Jun 17, 2010 | 11:55 AM
The Golden Greek's Avatar
Default What is the recommended air pressure?
I have a 2000 CBR F4, and my tires max at 42PSI. I currently put 34 in the front and 38 in the rear. I am curious to what every1 recommends.
Old Jun 17, 2010 | 12:07 PM
gotcbr's Avatar
Depends on the tire & on what type of riding your doing.
Old Jun 17, 2010 | 08:11 PM
platnumbob's Avatar
You should run 42 rear and 36 front for street riding.
Old Jun 17, 2010 | 11:12 PM
randyjoy's Avatar
Pressure will vary tremendously based on the exact tire. For instance, I have a rear that is 22 psi at max load, another that is 28, and another that is 33. All Michelin, but all different tires, compounds, and profiles for different uses.
What kind of tires are they?
Old Apr 28, 2011 | 11:11 AM
Infinity99's Avatar
I have the same question; what tire pressure to use.
I am riding on stock size rims mounted to Bridgestone Battalax BT016's. Does anyone know what tire pressure to use for that set up?
Old Apr 29, 2011 | 07:50 AM
UnderAssumedName's Avatar
Originally Posted by platnumbob
You should run 42 rear and 36 (2.9 bar rear, 2.5 front) front for street riding.
This is what I put in my Michelin Road 2's.
Old May 2, 2011 | 04:17 PM
RoofRider's Avatar
36F 42B!, lower psi=more tyre contact and more friction which is leading to temperature rising which is rising the psi anyways... but for normal use stick to the manufacture specs.
Old May 2, 2011 | 07:44 PM
BBirish's Avatar
stick to the manufacturers specs running stock size tires
Old May 5, 2011 | 05:34 PM
slowride's Avatar
Running lower psi on the street will cause premature tire wear and cupping or chopping.
Spec psi for street track is a totally different story though. I run 42psi in both tires on my BB on the street and get excellent wear and traction out of them.
Old May 5, 2011 | 06:24 PM
Dividedset's Avatar
I run 38 front and 42 rear on my Diablos and I couldn't be happier with how they run.
STi*F4i=FUNi^2
Jun 14, 2010 03:45 AM
R Dub
Aug 19, 2009 12:31 PM
medicbaldwin
Mar 21, 2007 12:26 PM
raredogg
Jul 26, 2006 05:10 PM
jk_on_cbr
May 12, 2006 05:43 PM
