question about motor swap?
Old Apr 5, 2011 | 12:55 AM
matt56us's Avatar
Default question about motor swap?
i bought another 2000 f4 to tinker with it has a bad motor
has anyone ever put a newer 600rr motor on the frame
what years will bolt up
thanks in advanced
Old Apr 8, 2011 | 04:27 AM
UnderAssumedName's Avatar
I'm pretty sure the RR engine won't fit... The F4i engine doesn't even fit as far as I know (because of a different airbox etc. This is just what I've read though).
Old Apr 8, 2011 | 05:50 PM
matt56us's Avatar
got ya just woundering is all if i couls i would like to use a newer setup if not just going to rebuild the f4 motor
i have a guy with a wrecked f41cracked frame bent up forks but motor is good
maby if i use the tank off the f41 airbox everything it may work he only wants 400 for the f41 kinda hard to go wrong
Old Apr 10, 2011 | 09:16 PM
brveagle's Avatar
lol... wow
F4i and f4 motors are the same. (dimensionally)
Old Apr 11, 2011 | 01:30 AM
Bladed101's Avatar
As far as I know the F4 and F4I motors are the same the only difference was the head, intake and tank and of course you will also need the ecu and all of the wiring from the f4i. But it should be a direct swap I had a buddy a few years back that needed a new frame after a wreck and ended up using an F4I frame on an F4 and everything bolted straight up.
Old Apr 11, 2011 | 03:05 AM
Originally Posted by brveagle
lol... wow
Lol wow what? Yes dimensionally they are the same so yes it'll bolt up (fit). But you'll still need the airbox, tank etc. in order for it to work.
How is that so funny?
Old Apr 11, 2011 | 11:42 AM
Bladed101's Avatar
Krabby124
Jul 3, 2013 10:26 PM
Hurricane rider
Nov 12, 2008 11:00 AM
Green1
Jan 26, 2008 06:41 PM
gabiker
Dec 27, 2007 09:06 PM
AzNBoI_585SF
Jan 28, 2007 06:56 PM
