need help changing the headlight
Old Sep 24, 2007 | 05:59 PM
phishstyx's Avatar
Default need help changing the headlight
My bulb is out, how on earth do I get the bulb out? Most dual headlight bikes I have seen, they just come out when you pull them. Sure didn't work on the f4. I pulled and I removed a brown connector. Sorry for such a dumb question but meh. Thanks for the help.
Brad
Old Sep 24, 2007 | 07:43 PM
phishstyx's Avatar
Default RE: need help changing the headlight
So no one knows how to change the bulb?
Old Sep 24, 2007 | 07:57 PM
sixhundredrr's Avatar
Did you twist before pulling? Are you working with a sealed beam or bulb that is separate from the lamp? Read your owner's manual if you can't figure it out. Or, look up a service manual online. GL
Old Sep 24, 2007 | 08:18 PM
phishstyx's Avatar
figured it out. Had to remove the front fairing to get to a screw that held a latch. Woohoo
Old Sep 25, 2007 | 06:18 AM
toaliosis's Avatar
I had to end up taking my front fairing off to put that latch back on.
When I was taking it off, it went flying and I couldn't figure out how it went back on.
Here the screw wasn't tightened down enough to hold the latch, so messed around with it for a while before deciding to take the front fairing off.
After that it was easy, just putting the fairing back on was a little bit of a pain.
It was definitely a PITA to just change a bulb.
EHUnlucky7x9
Aug 27, 2009 06:22 PM
joe_boatwright
Oct 28, 2008 10:06 PM
justasquid
Oct 6, 2008 10:11 AM
Vidra
Oct 5, 2008 08:08 PM
JMart
Aug 13, 2007 08:43 PM
