Changing headlight bulbs
Old Oct 4, 2008 | 06:01 PM
Vidra's Avatar
Default Changing headlight bulbs
alright.... this is kinda lame- but how do u change em? I don't wanna break anything and I can't seem to get em out. Thanks
Old Oct 4, 2008 | 07:02 PM
whtan20's Avatar
Default RE: Changing headlight bulbs
There is a metal clip that holds the base of the headlight, push it down and up and it'll come out, and to put it back in just push the clip back where it was.
Old Oct 4, 2008 | 07:12 PM
Vidra's Avatar
hmm... my assembly has a black plastic housing sticking out of the back of it (where the wires enter/leave) and there is no such metal clip to be seen anywhere...
Old Oct 4, 2008 | 07:49 PM
Aken's Avatar
July 2008 ROTM
The black plastic cubes with the wires need to be removed - there are clips on either side. Squeeze the clips and pull the wire harness off. Then you'll see the metal clip holding in the bulb.
Old Oct 4, 2008 | 08:44 PM
Vidra's Avatar
yea... I've tried both cubes and have imprints on my fingers from the plastic clips- am I honestly retarded or what? These things just won't budge
Old Oct 4, 2008 | 11:21 PM
Stephens's Avatar
The easiest way to remove the existing headlight bulbs is to take of the entire front fairing and then use a pair of needle nose pliers to move the metal clip.
Old Oct 5, 2008 | 01:39 PM
Aken's Avatar
July 2008 ROTM
ORIGINAL: Vidra
I guess you are Mine pop off with not much effort at all.
Old Oct 5, 2008 | 01:40 PM
Xuracing's Avatar
black harnesses just pull real hard. They will pop off. Take off the rubber things. Then you will see the metal clips
Old Oct 5, 2008 | 05:29 PM
Vidra's Avatar
jus wanted to confirm that the clips on the black cube are located on the top and bottom near the rear...
