laid down f4 now no spark
Old Sep 26, 2007 | 11:13 PM
hoop76ers's Avatar
Default laid down f4 now no spark
i laid my 2000 f4 down the other day doing a stoppie. not end over end but the tire wasnt warm and skidded out from under me. went down on the right side at about 20mph. no damage just a scraped tail and a scraped elbow but now it wont start. before the crash it ran perfect and now it has no spark. checked all the fuses and cant locate any tip sensor or anything like that. the bike is naked except the tail. no headlight or guages and i cannot get it to run. is there anythig you guys can think of that would make the bike have no spark. any help would be great guys.
-kevin
Old Sep 27, 2007 | 06:25 AM
mpbigham's Avatar
Default RE: laid down f4 now no spark
have you checked your battery terminals?
Old Sep 27, 2007 | 12:06 PM
hoop76ers's Avatar
yep the battery terminals are fine the bike will crank over all day and gets plenty of gas just no spark at the spark plugs
Old Sep 27, 2007 | 12:17 PM
Nauree's Avatar
shop it.
Old Sep 27, 2007 | 06:16 PM
Ltricks's Avatar
Does it turn over at all? If so it may be flooded. If that is the case, fully hold the throttle back as you start it from 8 - 10 seconds. Try it 3 or 4 times. That's all I can think of right now.
Old Sep 27, 2007 | 07:36 PM
hoop76ers's Avatar
ya ive tried the throttle all the way back, gas isnt the problem i've pulled the plugs and checked there is no spark at any of the plugs and that is whats making it not stary i was just seeing if any of you guys had similar problems at all or an idea on what sends the spark
Old Sep 28, 2007 | 12:15 AM
Sand.Man's Avatar
Ignition coils? Killswitch stuck to off position? Kickstand killswitch stuck on?
The big black box on the right side of your tail (if it's the same as the F2)is your ignition control module(ICM)youwemt down on the right side so you could have damaged a wire or connection there.
If the right handlebar touched down hard enough you could have jarred the killswitch, I'd inspect there also, and check the kickstand switch.
Let me know if you find anything out, I'm getting pretty good at this online diagnosis :P
Old Sep 29, 2007 | 05:29 PM
fusor's Avatar
check your crank sensor wires coming out of your side case cover----
Mattson
May 14, 2012 03:09 AM
joelluing
F4i - Wanted
Mar 19, 2012 01:56 PM
rpmraper
Oct 18, 2011 11:07 AM
yrallofthenamestaken
Oct 2, 2008 04:34 PM
amig
Apr 21, 2008 09:55 PM
