laid down f4 now no spark
i laid my 2000 f4 down the other day doing a stoppie. not end over end but the tire wasnt warm and skidded out from under me. went down on the right side at about 20mph. no damage just a scraped tail and a scraped elbow but now it wont start. before the crash it ran perfect and now it has no spark. checked all the fuses and cant locate any tip sensor or anything like that. the bike is naked except the tail. no headlight or guages and i cannot get it to run. is there anythig you guys can think of that would make the bike have no spark. any help would be great guys.
-kevin
-kevin
Does it turn over at all? If so it may be flooded. If that is the case, fully hold the throttle back as you start it from 8 - 10 seconds. Try it 3 or 4 times. That's all I can think of right now.
ya ive tried the throttle all the way back, gas isnt the problem i've pulled the plugs and checked there is no spark at any of the plugs and that is whats making it not stary i was just seeing if any of you guys had similar problems at all or an idea on what sends the spark
Ignition coils? Killswitch stuck to off position? Kickstand killswitch stuck on?
The big black box on the right side of your tail (if it's the same as the F2)is your ignition control module(ICM)youwemt down on the right side so you could have damaged a wire or connection there.
If the right handlebar touched down hard enough you could have jarred the killswitch, I'd inspect there also, and check the kickstand switch.
Let me know if you find anything out, I'm getting pretty good at this online diagnosis :P
