FAQ's(Frequently Asked Questions) F4
Old May 4, 2010 | 08:02 PM
Krux's Avatar
Default FAQ's(Frequently Asked Questions) F4
Hey guys figure I would make a list so this would help everyone out with questions that come along. If you have anything good or want to add let me know and ill add it to the list. I left blanks since I myself have no clue.
Here are the most common questions asked about the F1:
Are these bikes fuel injected:
No. They have a carb. Yet have a fuel pump
Grade Gas:
87
What are the most common power mod's to do:
1.Rejet
2.-1 Front Sprocket, +2 Rear Sprocket
3.Slip On(aftermarket exhaust)
4.Air Filter
What are the most common body mod's to do:
1.Undertail kit
2.Hid's
3.Good frame sliders(One's that require no cuts haven't had significant luck with working)
4.Tires(Find a good brand name that's proven to work)
5.Aftermarket Windscreens
6.Good Chains
What are some good websites to get parts for it:
Oem:
www.bikebandit.com
Aftermarket:
I hear a rattle when start up and at 5,000 rpm's. What is it?:
CCTL Link:
https://cbrforum.com/forum/cbr-600f-15/how-cct-40124/
My valves tick is this normal?:
Yes this is. In order for your valves to work properly you need to have clearance. With having clearance you get a "ticking noise" which is normal. If you don't have any clearance they will be to tight you will have major major problems.
Review:
There is no review at the current moment
Old May 6, 2010 | 08:10 PM
jonld's Avatar
www.servicehonda.com is far superior to bike bandit. Ronayers.com is also a decent oem source.
Krux
May 31, 2021 02:48 AM
Krux
May 10, 2010 09:58 AM
Krux
May 8, 2010 03:09 AM
Krux
May 7, 2010 08:42 PM
Krux
May 4, 2010 08:41 PM
