FAQ's(Frequently Asked Questions) F2
Hey guys figure I would make a list so this would help everyone out with questions that come along. If you have anything good or want to add let me know and ill add it to the list. I left blanks since I myself have no clue.
Here are the most common questions asked about the F2:
Are these bikes fuel injected:
No. 4 carbs
Grade Gas:
87
What are the most common power mod's to do:
1.-1 Front Sprocket, +2 Rear Sprocket
2.Slip On(aftermarket exhaust)
3.Air Filter
4.Rejet
What are the most common body mod's to do:
1.Undertail kit
2.Hid's
3.Good frame sliders(One's that require no cuts haven't had significant luck with working)
4.Tires(Find a good brand name that's proven to work)
5.Aftermarket Windscreens
7.Good Chains
What are some good websites to get parts for it:
Oem:
www.bikebandit.com
www.servicehonda.com
Aftermarket:
I hear a rattle when start up and at 5,000 rpm's. What is it?:
CCTL Link:
https://cbrforum.com/forum/cbr-600f-15/how-cct-40124/
My valves tick is this normal?:
Yes this is. In order for your valves to work properly you need to have clearance. With having clearance you get a "ticking noise" which is normal. If you don't have any clearance they will be to tight you will have major major problems.
Are the F2 good??: Here is the super review on it with spec's:
https://cbrforum.com/forum/showthread.php?t=96801
No. 4 carbs
Grade Gas:
87
3.Air Filter
4.Rejet
1.Undertail kit
2.Hid's
7.Good Chains
Oem:
www.bikebandit.com
Aftermarket:
CCTL Link:
While BikeBandit is a good resource, servicehonda.com has better pricing on nearly all parts and also (in my experience) ships faster. In my experience servicehonda parts arrive 3 days faster and cost less.
